Hey everyone,
I'm new here but stumbled upon the site and I will be posting in the future!!
I just recently bought this four wheeler and it was my first atv purchase. I got a pretty good deal as it just needed some TLC and I'm a student on a budget.
I really need some help with my carb and I am completely stumped. I bought a rebuild kit because the needle valve was leaking by when the engine was off and causing it to overflow. I rebuilt the whole carb, put it back on and the thing was idling high. Found out later this was because I had the throttle hooked up wrong but I got that corrected. I thought something was wrong with the carb itself so I broke it down and went back through it. The one piece I hadn't changed was the "main nozzle" as it's called on the parts diagram. The throttle needle goes through this before it goes to the jet tube. Well I messed up the new one trying to install it because it would seat into the carb good and ended up having to put the old one back in it. It was a little messed up where I had to drive it out, but just slightly and worked with it for a few and got it back right. I got everything right and put the carb back on and now I'm having a big problem... I cannot get the thing to take any fuel. It will barely idle and if I give it any throttle at all it cuts off. I have taken it off and cleaned it 5 times, made sure the pilot screw was adjusted out to 1 1/4 turns, and it had the correct float height (21-22mm). Also it appears the bowl is getting a decent amount of fuel because every time I take it off and some fuel leaks out of the vent tube there is still a lot of fuel in the bowl. So now I'm just confused and don't know where to turn next...
Sorry for all the details but I just wanted to give someone enough info to possible help me! Even if you can't I would appreciate if you could direct me to someone who possibly can!
I would appreciate any advice at all!!
Thanks again.
    • By geezer99
      Well, I bought the Axis 500 sold at Lowes for $8999 a couple days ago.  This post will be about my impressions as I use, fix, and abuse the machine.  I will add to the post as I gain experience with it.
      Thanks to other posters on this site warning of new machines with loose hardware, one of my first actions was to crawl all over it checking fluids and connections.  Zirks were all freshly greased, fluids in engine, and gear boxes were up to level.  One of the little gas struts that help lift the bed to dump was dangling with only one end connected, and the other strut had not been fully tightened.
      The rear gearbox does not have a differential in it.  It is essentially a solid axle.  Tight turns on lawn will leave tracks, and turns are not as tight on pavement.  In my case this won't matter much, but if you plan to use it on a lawn, this will create tracks on turns.
      To check engine oil you need to remove both front seats and a plastic cover.  This according to the manual.  I'm pretty sure it can be checked with that stuff in place, either from under or above, but that remains to be seen.
      I am not used to a CVT transmission.  I am used to a clutch and multiple gears.  This one requires giving it plenty of gas out of the hole and then backing off to get it to shift up.  I'm sure I will get used to it, but I'd like to be able to take off quietly if I want to.
      The doors have bungie cords to act as springs to close them.  I removed the driver door so I would not need to fight the constant pressure to close.  Problem solved.  I will leave the passenger door as is.  Gotta keep the grandkids safe.
      Here is some stuff I like:
      I was concerned about there being enough torque to slowly climb a steep hill.  There is.  I will elaborate more on this when I've had it on my steeper trails.
      The display has dedicated lights to indicate status of gear position, low oil pressure, over temp, and a bunch of other stuff.  This helps a beginner with feedback that an action taken was successful.
      The sparsity of knobs on the tires dig in well on most surfaces.  I bet they wear out fast on pavement.
      The tilt bed has a tail gate that is easy to operate.  Much like early Japan pickups.
      Steering is responsive and little slack.  Remains to be seen how long to get loose since the u-joints are operating at quite sharp angles.
      Seats are pretty nice.  Will be interesting to see how long it will take me to poke a screw driver though them.
      Seat belts are included to hold grand kids in.  Won't go over 5 mph if both aren't buckled.  Yeah, it works to buckle them empty.  Doing this leaves the belt high on back, so you don't have to sit on it.
      Hauling it home, my trailer wheel wells were too close together to clear the tires of the UTV.  This required driving it off center a bit, with one set of tires inside the wells and one side driving over the wheel well.  Creeping over the one well required climbing a 10 inch vertical well.  The ability to lock the front axle differential kept both front wheels pulling as I drove the one side up and over the wheel well.  The guys at Lowes were impressed.  They won't touch any but an unobstructed flat trailer loading.
      tom
    • By Martin82
      Hello to all,
      Im looking for a main wire harness for Polaris sawtooth 200,
      Thanks for info
    • By BillR94
    • By HHurks
      Hi to all
    • By fixitforfree
