By CaptJim
Hello guys, I hope I am not invading your space, but as you can see the current state of my project here it's not but about 50% ATV. I am hoping that some one here can point me to a wiring schematic that I can reference since the "Complete wiring harness" i purchased from Amazon did not include a diagram of any kind.
The ones that I am finding on line vary greatly but none show the connections for the separate 5 wire connector coming from the motor.
Can someone tell me where these wires go?
Thanks in advance for all help!
By dalton7545
By Admin
By jashadams
Snapchat-1142015191.mp4 -
By p5200
Similar Tagged Forum Content
- 1 reply
- 3,063 views
- 0 replies
- 5,061 views
- 0 comments
- 2,686 views
- 3 comments
- 3,179 views
- 0 replies
- 2,737 views
