Join Today, It's Simple and FREE!
1988 Suzuki lt250 Quadrunner - Tune Up
By
oldandnew, in Suzuki ATV Forum
Similar Topics
By Dra O
posted a while back - it was running at one point - I have all the plastic shroud off - it's down to frame and engine now
-fuel pump: when line from petcock is attached, no fuel comes out other side to carb; the line to the carb is open (can blow through it); I thought when I cranked engine that the pump would spit out fuel on other side but it does not; I removed fuel pump and opened it up - diaphragm looks good - but internal areas had lotsa calcification build up - I cleaned this out and dried it good - the clear plastic pieces (?diaphragms) aren't broken - the spring w/ steel ball on end moves freely; am putting it back on tomorrow; but can anyone answer about the pump? isn't it supposed to pump fuel through it... to other side... to carb? puzzling
-along with fuel pump: I replaced petcock 3 weeks ago (gas tank had rusty fuel in bottom - cleaned it out prior to new petcock); when I turn petcock arrow NOT to on or reserve, fuel comes out of line; when I turn it to on or reserve, fuel doesn't come out; puzzling
-I don't know what's on back of fuel pump - it's a valve that has a hose coming out of it - looks like it goes to engine/carb - I haven't traced this out yet - what is it?
-can squirt gas on air filter and engine will run for 2-3 seconds then stop - fuel in top of carb (under diaphragm) does same
-it likely needs carb rebuild - will get to this - but something isn't allowing fuel to get from fuel pump to carb
-I THINK it has a mikuni model x carb - diaphragm is ID 26mm OD 68mm - hard to find inexpensive diaphragm, I guess because it's a model x
-last thing - I replaced solenoid due to old one clicking; I HAVE to be charging the battery or it won't start/turn over - battery just goes dead; but if charging, it'll turn over nicely; i'm guessing it's a bad battery
-any help appreciated - I've never owned an ATV before - inherited this beast from grandparent in-law
By Mike Johnson
Does anyone know what the 3rd item is behind the battery on this ATV ? I know 1 is the, solenoid1 is the CDI box, what is the 3rd.
By Daniel Gibson
Working on a bayou 220 that has been ran extremely hard it's whole life. Literally had almost an inch thick dirt/oil covering the motor. Yeah that bad. Surprisingly it runs though. I cleaned the carb and tank multiple times. They're clean enough to eat off of. Readjusted valve lash and set timing. Was about 3 teeth off. It cranks good and runs good only problem is I have to cover the carb intake basically choking the hell out of it for it to start. The com choke works fine. It does this each time I start it regardless of temperature both ambient or motor. Wth? Compression is at 115psi I get 130s if I put a little oil in the piston chamber. Please help. Thanks
By JC4x4
My Honda Fourtrax won't start. The starter is kicking the engine over, but it won't start. It sat for about a year while I was living away, so I thought it might have been bad gas. I completely drained the fuel, flushed the fuel lines and filled it with fresh gas. However, still nothing. It started and ran fine the last time I used it. Any suggestions on how to diagnose this? It could be fuel or electrical at this point. Is there an easy way to rule one or the other out? Thanks
By David Miller
Does anyone know how to access the check engine codes on a 2018 450 sportsman. Just changed battery and spark plug . It runs fine but the light is on and I need this to plow snow and need it reliable. Any ideas . Thanks
Similar Tagged Content
By wHarmon
Our 1988 Yamaha Terra Pro is finally seeing the finish line of becoming our new bush hogging tractor! I've had the terra pro for almost 2 years... we had great intentions, but after removing the fenders, fuel tank, and the carb, we let it sit up. Shame on us! However, the terra pro is cranking today. We cleaned the carb, figured out what goes where and where did that screw go! She smokes like there's no tomorrow, but that's okay! The only issue right now is getting all these lines hooked back up to the carb right! There is 5 lines to hook up to this thing!! And in our moment of drinking and removing parts, we cant remember how they go back on. I've found several diagrams online, but none showing the overall schematics of all the lines! If anyone has a service manual, or any way of helping us figure out what goes where I would really appreciate it!! I can attach pictures later if it'll help!
By Jers
I need to know what I have and what tire really go on it, Mine has 24x11x10 on the back and 22x8x10 on the front and I need new tire but I don't think are the right size. Also I can't find the model number listed but it looks like a 250 quadrunner 2wd and I think it is a 1987 maybe, can anyone help me, also I it has a rich running sound and I put a carb diap in it and cleaned the carb. is there a jet needing replaced?
By Kyboy
Iam looking for help seperating the rear brake drum and the cover. Any suggestions would be greatly appreciate
By alexcross324
Hi all, my second post here
I got an old Yamaha 88 moto 4 and I have a problem with my overflow hose from the carb.
When I put the gas switch to ON a big amount of gas is leaking from the overflow...so I start using my quad with the gas switch to RESERVE wich is also leaking but less than in ON position.
I dont ride a lot..but in a week I empty my gas tank.
Strange.
I never clean my carb because Im new to quad world and dont have the service manual...so I need you point of view.
Thanks guys!
By alexcross324
Hi all, I try to find this manual in the threads but you have a lot of stock here
Cannot find this particular manual.
I found it for YFM200 but not sure if they are the same.
Thanks if you could help me with that.
Im new here so if I did something wrong, please tell me.
