2012 Polaris Sportsman - Diff Seal Change
hey guys, i am new to the forums but could use a little help. i am trying to change the seal where the drive shaft enters the front differetial on my 2012 polaris sportsman. i am under the impression that all i need to do is knock out the roll pin on the saft and the whole assembly will slide back so i can get to that seal. is this correct? i have taken off my wheel and given the pin a few whacks using a punch and it hasnt budged. i even tried using some WD40 with the same results. am i doing something wrong or is it just being stubborn? any suggestions to make my life a little easier. there isnt a lot of room down there to work with a hammer with my shock there. any help for a noobie would be greatly appreciated.
    • By BruceG
    • By BenJammin
      I did a compression test on my 2005 Bombardier Traxter 650 CVT and it's 75 PSI.  service manual only talks about leak down test.  No specification for engine compression the manual.  What does 75 PSI tell me?  Thank in advance.
      A little history of this machine.  640 miles.  Picked it up about 2 years ago, not running. Probably the computer.  Tested all circuits and confirm it was the computer.  Long story short, I watched a Youtube video and fixed the computer. ATV now started and runs.  BUT, it tops out 20 MPH.  I cleaned the carb 3 times also using a Mikuni carb kit after the second time.  Slide in carb is going up and down.  Only adjustment for fuel is at 1.5 turns out.  NGK Sparkplug had soot on main part but brown on the electrode.  Champion sparkplug is brown.  I check CVT clutches and they both appear to engage like they suppose to.  Checked valve clearance it's 0.00, I can't get any feeler gauges in-between.  I check timing chain I believe it's in the correct position and hasn't skipped.  I removed muffler plug and drilled into muffler to try and make sure it wasn't plugged.
    • By Clydaho
      Any other ideas?
      Thanks for any help,
      Clyde
    • By kantrud97
      Thank you in advance
    • By DarkRider
