I'm experiencing a similar issue with mine. Talked to the Kawasaki dealer and all they could offer for advice is to start changing electrical parts. At $400+ for ignitors and controllers a person don't want to make many wrong guesses.
Just had a second thought. I've pretty much narrowed mine down to an electrical problem. Yours could be fuel related also. I checked the pump for pressure and flow. Also removed the bowls and checked the jets for obstructions. So I'm pretty sure mine isn't fuel issues.
  • 3 years later...
    • By RadRob
    • By Eisaks777
    • By Snick
      ^PINOUT:
            5   6
            2   4
           1    3
