I have a 01 raptor and recently had to bore it out to a 686 because it sucked in a bunch of sand. Now I have no torque or power in the first third of the throttle. I am hoping that someone else knows what is going on with it
    • By Gtc4d
      Thanks.
      Todd
    • By Adamb2025
    • By jordan_ATV
    • By Frank Angerano
