On my arctic cat when i put the key in to ignition in turns on the display and then a couple seconds later starts flashing EFI and going from 0 to 110 on the speed odometer. What could be wrong with it ??
    • By tepin
    • By Shorty51
    • By randyoct
      Will the top end of a 400 fit a 366 the price is so much cheaper
    • By BillR94
    • By BillR94
      Thank you for your time
      Bill
