The other option might be to use some from a newer trx, have been in your position a lot as all the machines I own are older and one is old and built in eastern Europe. It is becoming a joint effort between Hungary and Spanaway, Washington. It is good to see you're keeping the old iron running! I do it because of redneck engineering and an Amish budget
are your calipers missing? You can get rebuild kits from moose racing or quad boss.
It has drum brakes, front only. Need functional wheel cylinders, mine have frozen bleeders and I can't seem to break them loose.
I've tried to locate wheel cylinders the same size, but can't find any that small. I'll keep looking. Thanks for your input
understood. What has worked for me has been soak in penetraing oil, preferrably kroil, then put the cylinder on a hardwood block and rap straight down on it with a small hammer a couple of times. It sometimes takes a couple of times but usually works. the other two options that come to mind would be to drill the screws out in small increments until youre close to the outside diameter, keeping in mind that the bleeders seal on a taper at the bottom, then using an eazy out . Good luck
I did a premature button push, its a senior thing. The other thing might work is drill a hole down through the screw slightly larger than he hole, thn use a left hand drill bit 1/32" bigger VERY SLOWLY. drill through again. If everything works like it is supposed to the first pass will heat everything up enough that when the left hand bit starts though and grabs, which it will, the screw will back out. What happens if you hurry the process or dont have a reversible drill that can run really slow you will break the bit in the screw, causing you to speculate about the relationship I had with my mother or mothers in ganeral and you will have a much bigger dilema
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
