My bayou was running. Turned it off. Went to start it again about 20 minutes later and nothing.... no electrical power. No lights, no neutral indicator light. battery good. Jumped starter and it turns over but doesn't start. I'm not sure what the problem could be. Maybe ci igniter or rectifier?
Edited by Ajmboy
Changed title
So if you connected a jumper pack and it cranks, your battery has issues. if it cranks and doesn't start, its either spark, air, or fuel. I would fix the no start/electric issue first by checking connections and ignition wiring to the key. After you fix that, dig into the no start by checking spark and fuel delivery.
    • By realpilot
    • By logray
    • By OldATVowner
