By p5200
By kawasig
I have a 1987 Suzuki dual range 230 and a 96 bayou 220. I'm trying to figure what oil to use. I normally put Amzoil synthetic in most everything. But I understand there are concerns over the wet clutch. I've heard rotella 10w40 full synthetic,5w40 synthetic,10w30&40 non synthetic. I do live in Michigan, so temps cold and hot are encountered. It could be below zero or 90 degrees farenhight. I don't have manuals for them. Any help is greatly appreciated!
By rgeiser
just wondering if i pay the thirty dollars how soon will i be able to access the manuals?
By Shane Thomas
Not sure if this is the spot for this but I am looking for the nit and bolt to hold on the clutch lever and one of the rear bolts on the swing arm to adjust the chain on my 06 kfx400. I’ll try and add a couple pictures.
anyone have anything lasting stopping?
Thanks in advance
