When comparing dump carts for ATVs, you mostly find steel carts out there from various online retailers and places like Sears and Home Depot. My first choice a few months back was going to be to pick up one of those steel carts for my ATV, but then I was able to get my hands on Quadboss's Swivel Dump Cart that has this hardened "Structual Foam" body that is rust proof. This dump cart came in a large box which I snapped a picture of below. The contents of the box were the dump body, 2 wheels, frame, trailing arm, and hardware & pins. I spread the items out and followed the easy to read instructions. They illustrated every pin, nut, and bolt size, so that you know exactly where they are supposed to go. The steel frame parts of this cart are heavy duty 11 gauge steel, and along with the 1 inch axle, the load capacity is able to be set at 1,250 lbs. Assembly was pretty simple and tookCIMG0145-300x224.jpg about an hour all together.
The longest part of the install was attaching the dump body to the frame with 10 bolts. It would probably go quicker with 2 people, one holding the dump body and feeding the bolts, and the other holding the frame, and screwing on the nuts on. Once that part was done, the rest was pretty easy. I was impressed with the fact that the wheels had grease fittings for the wheel bearings. Once it was all put together, attachment was easy to my ATV hitch receiver hole with a supplied pin. You can use a hitch ball, but it's not necessary.P1010137-300x225.jpg
Now it was time to test this thing. I took it out of the garage and around the property, over some bumps and a hill or two. It was very stable empty, so then I decided to do some work to fill her up. It was a nice day finally, most all of the snow had melted, and it was time to lay into some yard work. I had planned to dig out some dirt from one area and transport it to an area where I needed some more soil. I pulled up next to my mound of dirt and started digging. I filled the cart up with two loads and dumped them both in the area that needed the dirt. Dumping it requires you to step on the release mechanism pedal that has anti-slip spikes, and lift up the cart. I suppose if you fill it up with overweight stuff, it's going to be a pain to lift it on your own. The dirt all came out except for the last 10% that IP1010138-300x225.jpg used my shovel to get out. The sloped rear on the dump is nice. Another nice feature is the swivel, which allows you to turn the dump up to 100 degrees before dumping. So that was pretty easy, so I decided to load some other things around the property, like rocks, brush, twigs, and branches. This is where the optional fence attachment would have come in handy. I may need to get that next. I'm still waiting to take it up on the trails. I highly suggest this dump for anyone looking for a high quality work horse of a dump, as an alternative to the traditional steel carts.
QuadBoss Website Quadboss_logo_100_.jpgQuadBoss ATV Trailer Product Video
Find ATV Dump Carts on Amazon
7 years later and I'm still using this same dump cart. It's done various jobs for me every year and hauls a good amount of weight. Just posted the pic below in the gallery. Last weekend I took apart some old wet outdoor steps that were very heavy. I was throwing them into the cart, the plastic held up and continues to hold up without issue. Never had to do anything to this thing. I would buy another one in a heart beat!
    • By Panupong Pradchaphet
