This is a review of the QuadBoss 15 Gallon Spot Sprayer. This sprayer comes in handy for spraying liquid fertilizer or even just watering around your property, which is what I used this sprayer for. I planted 15 evergreens on the other side of my property, too far to get a garden hose to...
The sprayer came in the box essentially as one piece, everything like the motor and hoses, already assembled. You can mount this unit on your ATV front or rear rack. I opted for mounting on the rear rack this time, and secured it with a tie down. All I had to do was wire it to a power source. I went to the auto parts store and got myself a 12v automotive quick disconnect and some wire. Wired to my auxiliary power under the seat of my Yamaha Grizzly.
Plugged it in and filled her up with water to test out. The pump primed up and sprayed very nicely. The pump goes on as soon as you start to spray to maintain pressure. The pump also has an on/off rocker switch I forgot to mention. This sprayer comes with a 10 ft hose and adjustable plastic nozzle. I took a ride to the far end of my property and watered all my newly planted evergreens. Came in real handy, was able to get off my ATV and hit a 25 foot circumference or so, as needed. If you are looking for a way to get some water or chemical out to far areas with ease, this unit makes farming and gardeing a breeze.
    • By jay41198
    • By oztrax
      MAX 4 6X6 2008
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By Sha35297
      I have this bike in my shop for a customer. It was sunk completely under water and left running until it killed. I did a complete engine rebuild. Replaced all bearings, crank, oil pump, and various other components. Engine starts and runs great. It will shift up through all gears perfectly in automatic and in ESP, but when slowing down it gets to 3rd gear and the MIL "-" light comes on and stays on. No flashes or anything and it will not shift gears. Kill the engine and restart in ESP mode and it is able to shift to neutral and start over. Does the same thing while down shifting in ESP mode. I replaced shift angle sensor with no improvement. Checked oil pressures as per repair manual "74psi" and higher with higher RPM's. With no MIL codes to point at an issue. I am at a loss as to what else to check or replace. Has anyone else ran across this issue?
    • By TravisCr
