1991 Trail Boss 350L 2x4 overheating HOT light
trailboss350
Hey all - I am new to the forums but I hope you can help and in the future I can return the favour.
I have a 1991 Trail Boss 350L 2x4 that is running hot after being on for about 10 minutes. I have checked the coolant - levels good. Burped the coolant using the 10mm bolt on top of the engine - good. The fan however was bypassed from the censor on the rad directly to power when the key is turned. Now I am thinking that may be the issue or a faulty water pump. (The hose at the top of the engine is hot but the one at the bottom and to the rad is cold). Any further suggestions or recommendations on previous attempts are greatly appreciated!
Thank you in advance!
Welcome to QUADCRAZY 😁
Is the fan on all the time with the bypass? What's interesting is that there is definitely an underlying issue if the fan needed to be bypassed to the ignition and was not going on with the temp sensor. How do you know its overheating, is it hot, light come on, boiling over?
34 minutes ago, trailboss350 said:
I have not yet changed that part but would this come on after 5-10 minutes or right away if it was faulty? Also, the hose at the top of the engine is hot and the bottom one is cold. Could it be anything else? Thanks again for your help!
Sounds like coolant is not circulating then and that would lead to a bad thermostat. I don't have a manual, there must be a thermostat in that ATV.
    • By pitts
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By newguy024
    • By mga
