I just purchased a yamaha big bear.  I was told that it was a 2003 400 big bear.  Now I'm not so sure.  I have put the vin in a few different decoders and got 3 different answers. One told me the closest vin was one of 3. another told me they couldnt find it and the 3rd said it was some 2 stroke model (which I know it isn't )
the vin is 5Y4AH08W9yA007113
could any one help me out
Are you certain that vin  is correct ?  This is an European  motorcycle/  atv  parts supply  company that has a  list of  Yamaha  ATV's  codes from 2000 to  2012.
Your  vin  prefixes  don't  match anything they  list .. They  do  offer  to check  a  vin  you send them  and  reply  by  e-mail..  They  list neither  the  5Y4 prefix nor the  AH08W model  code; so  those may  be  different for  North American  models.
You could try contacting them  and see if they  can  help.
https://www.motorcyclespareparts.eu/yamaha-parts/yamaha-model-prefix-atv-quad.aspx
  I also tried running your VIN  on this site and  it came up with an  unknown
http://www.atvstyle.com/atv-vin-number
Other decoder sites  also  said they could not run that  VIN
Thanks. I have an email into them.  yes. I checked it and re checked it. the vin is right in the spot it is supposed to be and doesnt appear to be altered in any way.   I did find this site that was able to decode it  http://en.vindecoder.pl/5Y4AH08W9YA007113 .  and it gave me this info   but the actual model was missing
Vin number analize
Entered VIN 5Y4AH08W9YA007113
Corrected VIN 5Y4AH08W9YA007113
Squish VIN 5Y4AH08WYA
WMI 5Y4
VIS identifier N/A
VDS AH08W9YA
Year identifier Y
Serial number 007113
VIN type normal
Check digit valid
VIN number">Check VIN number: 5Y4AH08W9YA007113 and learn more about the history of this vehicle.
General Information
Make Yamaha
Model year 2000
Manufactured in United States
Everything  I searched on  came  up with  a 2000 model too.   Searching from  that   site  and   it  could be  a  Big  Bear,  Kodiak  or Grizzly..  Yamaha  ,  like all  the  quad makers  makes several  models with basically thee same parts but with  slightly different  badges  and accessories.
  I saved that  VIN search site .  Hopefully  it will   help  another  sometime down the road.  When  I went to  register  my   Honda , I  had trouble with the  VIN  stamped on the  frame ..  it took some searching to  fine  the  proper   VIN because of the  rust  and   poorly stamped digits.  A  little  searching  plus  sanding  and using a  magnifying lass  Iwas finally  able to  get the  correct   VIN.  That's  why  I ask  others to double  check theirs.  Nothing  like 25  years  worth of trail  riding  and  corrosion  to  make  some  VINs  hard  to  read.
  Bought  my Honda  3  years  ago   and when  the provincial  gov't  decided we  needed to  register them and get  a   tag  for them  before we  could continue  to  ride  the  trails  and   logging roads .  Took  a  lot of frustration  to  get the  proper  VIN to  register  it  and get  my tag.  I don't  mind  helping others with similar   problems .. That's one good thing about being retired .  I  have time to  search  and play  on the  pc .  Now  if the pensions  just paid better ..   LOL
thank you
    • By cfherrman
    • By flyinbrian365
      Factory service manual
    • By flyinbrian365
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By Rockbottom
      What should i test next?
      thanks ahead
