We have a feature that I've seen some already using and just figured I'd post about it. Many of the current sites on the web allow you to tag someone like on Twitter within your comments by using the @..... like @Admin
Try it by typing the symbol @ and then start typing the member's name. They'll be notified of your mention. It's a great way to engage someone specifically in your posts.
  • Admin unpinned this topic
    • By davefrombc
      It would be  helpful at times to have a button  where we could cont the Admin. to  make some changes to  our posts.
    • By Maddman200
      Hello, I am in need of some help with a subscription issue, can an admin please message me that is able to assist me. I am trying to download a manual says I need a subscription but then I check and it says I have a subscription and when I go to try to buy a subscription it won't let me cause it says im subscribed already. Any help is appreciated. I have uploaded a few manuals in the past to help the library grow and have many more I can add as well.
      Thank you for your time
    • By Fishy09
      Hi folks I have been registered on the forum since 2012 & enjoy reading the mechanical issues and advice given to remedy them, I have not received the weekly newsletter since Feb 12 & just wondered if I had not been included due to lack of posts or input, there has been no change of email address or forum settings change from my side and miss my weekly fix following the current issues folks are having, looking forward to being added to mailing list again 👍.
      Cheers.... Fishy
    • By Quadman11
      Hi Guys, First post.
      I'm Having an issue with my KLF300 2X4.
      Just purchased a 2000 model KLF300, when i first rode is i noticed the gear shifting from reverse to first and vice versa was extremely hard and stiff.
      Now When the bike is running it is Shifting straight past neutral into reverse without using reverse lever, making neutral impossible to find. Also the neutral light and revese light has stopped working. To get the bike started i grounded the green wire coming from the switch so now i can start it again but the shifting issue is still there.
      I have adjusted the reverse lever and cable so that it is fully retracting but this hasn't changed anything.
      Can anyone recommend anything to check etc?
      Thank you.
