    • By C2INS
    • By Ejwill
    • By Charlesbrown
      I was given a 07 big bear 400 with all the options. The prior owner ran it through water and it started smoking  so he took the head off and gave up. I have  a bunch of parts in boxes and did a quick inventory.  I need a jug, piston, rings etc and thinking it’s better to buy a complete top end. Does anyone have a recommended site to buy parts? I plan to go oem, no china junk but if there are quality aftermarket manufacturers I’ll do an upgrade.
    • By McG75
    • By fishhouse3
