Banshee
-bored out to a 370cc (20 hours since rebuild!!)
-hinson styled clutch basket system and new heavy duty USA imported clutch, with heavy duty lever
-fmf pipes and silencers
-pro craden nerf bars
-durablue +2 rear axle
-x faxctor +2 swingarms
- douglas rims and razr 2 tyres
-k&n filter
-grippa seat
-aftermarket suspension front and rear
-taper handle bars
purchase of bike comes with:
2 sets of plastics - blue and grey
6 spare rims and 4 spre tyres
1 spare axle
bark busters
foot guards
all spare parts i have in my shed
this is a genuine sale of an awesome bike, all the work on the bike has been done by one specialized mechanic also
if you are GENUINELY interested please dont hesitate to email me on
[email protected]
please write: banshee sale in the subject line
thankyou
-Daz
    • By Eisenmatt17803
      Good Morning!
      Has anyone had a problem with the small aluminum 90 degree elbow popping out of the valve cover and blowing oil all over the place? It looks like it is simply pressed in and will most certainly repeat the offense. Any experience you all can share with this issue?
      Thanks in advance.
    • By quadnut20
      Just picked up a 2025 Yamaha Kodiak 700 fixing to do a EPI Clutch mod to it since I dropped bigger tires on it !! Air box , exhaust , and programmer next !
    • By Joeguy
      Did a top end rebuild, honed .010 over, new piston, rings, valve seals, etc. When i re assembled i only had like 30 psi of compression but then after it sat all night i now it seems to have gained some somehow, there is much more resistance pulling it over and i even got it to fire for a few pops. Issue i got is that it makes a loud squeak noise through the intake i believe (goes away when throttled so something with carb area) and it seems to not want to run well. I took head cover back off and timing seems fine so im not sure if something is sticky and that's why i got some change over time or maybe the valve lash is messed up after doing all this, i did get another cam for it but i wouldnt think it would make enough difference to need to re lash. Any insight on next step would be appreciated, i will be looking up how to do lash on these because it is a very weird angle to slip a feeler gauge in.
      Actually cam is slightly off now that i look at the picture, thought it was good while looking in person. Hmm.
    • By sunn
      The clutch engagement on my 2021 cforce 400s was approx 2700 RPM, very abrupt/not smooth.   I obtained a "kit" from RNG consisting of a blue painted spring (spring force unknown) with 12 gram weights, as measured on my postal scale.  Installation was easy; 18 mm and 30 mm (not 32 mm as seen on other writings) impact sockets for clutch housing removal.  The resultant clutch engagement was still up to approx 2500 and very abupt/not smooth.
       The original spring was labeled p/n 0951-1021 (specs for spring force 300/1600) with 18 gram weights.
      I called RNG who told me the kit should work fine for my ATV, but that wasn't the case as I found.
      The RNG spring was slightly longer than the stock spring, but felt slightly easier at initial downward force but had more resistance than stock as I continued to push down.  RNG would not tell me what the spring force was.
      I then tested the clutch with the RNG spring and the OEM 18 gram weights with the resultant engagement RPM of about 2050 RPM, a little smoother engagement but still not good.
      I am really struggling to get any answers on the best combination of spring / weights to achieve a smooth engagement of maybe 1800 RPM.  Note; idle RPM is approx. 1600.
      I have searched all the forums and cannot find good information, and RNG appears to be not willing to share information.  What gives here?  Anyone with experience to share?
    • By Coyote251
