Hi all. I just replaced the battery and the regulator in my 1995 suzuki king quad 300. It fired right up with the new battery in. Switched it off to go get my helmet and when i came back out i hit the start button and every light shut off and stayed off. Flipping all switches did nothing and no electric start. I checked the battery and it is reading proper voltage and neither fuses are blown. I pulled it with the pull start and it ran perfect all day long just no lights or electric start. I have done a start in gear mod so i am guessing that is why it started with the pull start. Every so often the neutral light will come back on but when I switch the kill switch to the run position it turns back off and wont come back on. I am not sure what to look for at this point so any help is greatly appreciated. I included a wiring diagram too just incase it helps. c1cdb7ea0208d44d7ce0bb66a7f8faaf.gif
Ok so after some more looking around i found that the smaller wire coming from the battery positive was corroded and broken. Crimped new male connector on and everything works as it should.
    • By docdoug72
    • By Thekevinjb
      thanks
    • By Atomusthenes
    • By RadRob
