    • By Coyote251
      I am hooking up a speaker on the rear of bike and want to use a factory auxiliary switched plug and not have to cut into the factory wiring or add another switch. I have read a bunch of posts that say there should be an auxiliary 12V connector in the front and one in the rear. I found the one in the front when I hooked up my winch but cannot find any in the rear. I have seen some pictures showing one on the right side attached to the down tube behind the side cover, but there is nothing on my 2024. Can anyone confirm that there is a auxiliary 12V connector in the rear on the 2024 700 Xmr? If so, can you please tell me where it is (with a picture if possible)?
    • By Coyote251
    • By killerklown
      Does anyone know the torque spec for the nut on the one-way clutch?
    • By huntindog
      TIA
    • By Slitzer
      Hi,
      Thinking about to upgrade with a performance exhaust.
      Appreciate tips on brands and where to buy (ship to Europe)
