I am hooking up a speaker on the rear of bike and want to use a factory auxiliary switched plug and not have to cut into the factory wiring or add another switch. I have read a bunch of posts that say there should be an auxiliary 12V connector in the front and one in the rear. I found the one in the front when I hooked up my winch but cannot find any in the rear. I have seen some pictures showing one on the right side attached to the down tube behind the side cover, but there is nothing on my 2024. Can anyone confirm that there is a auxiliary 12V connector in the rear on the 2024 700 Xmr? If so, can you please tell me where it is (with a picture if possible)?
Have you tried an AI search?..  I did and came up with this..  Hope it helps .
Rear Location: A second accessory connection is found on the right side of the machine, below the seat area behind the plastics or near the top of the rear strut.
I found the same thing but have still not been able to locate the accessory plug. I would figure that I would be able to see it without taking all the plastics off the back of the bike. Ideally, at the least I would like to confirm that it exists before I start peeling plastics off.
    • By colin james
      View File 2017-2019 sportsman 450/570 with eps factory service manual
      This  is the factory service manual for the 2017-2019 factory service manual for the sportsman 450/570 with electronic power steering
      Submitter colin james Submitted 09/06/2018 Category Polaris ATV
    • By Arizona
      Just recently bought a dead 06 Eiger, Can someone post or send me a wiring diagram for it:?
      Need to check all wires, no power in most places, Cant seem to read the ones from online manual,
      too blury and cant tell wire color. Just too small. Thanks Az
    • By Peisledder
      Hello, can someone help me? I have a MAP error code 102-3, and the MAP has 4 wires: light blue, orange, purple, yellow. I’m getting different results on what the wires are. I don’t have wiring diagram. Can someone confirm which is ground, 5v, MAP, and Temperature?
    • By BruinBeater
      Hey all, BruinBeater here.  Just joined up from the Pittsburgh, PA area.
      Got a Polaris Sportsman 1000 and a 570 in the garage that don't get ridden quite enough but looking forward to a family trip this fall.
      I'm the unofficial mechanic of the extended family.  In the past month or so I've replaced a transmission in a Chevy Silverado, rust repair on a Chevy Malibu, electrical repair on a Subaru Crosstrek, overheating issue solved on a Can Am Commander, and right now I have a pair of Grizzly and a Bruin 350 in the garage.  Both have a no start condition and have been sitting for 2+ years.
