Hi All,
I have an 87 lt4wd quadrunner 250 and the choke cable is not there, speedo is frozen, left brake handle is frozen, right brake handle and reservoir is missing but runs good and all gearing works. I'm starting with the choke install. I have the manual downloaded and printed (472pgs) It is hard to see. Any help is welcome, the first thing I did was oil and filter with front diff oil change coming up soon.
RUSTY
  • Like 3
I have a twin of this that I use for parts, that will work on a 1988 LT-F250  2WD . Any thing that is unique to the 4WD may be available. ie choke cable, carb etc. I have the from brake master cylinder and handle complete front driveline, short of the rt ft inboard drive axle, I will keep the engine top half but the complete gear case and engine lower unit will become available. As I said though anything that ill work on my 2 wheel I plan on keeping.
  Let me know if any of this is feasible for you.
Hope it works out for you.
Tim.
    • By RadRob
    • By Mhatayas
