By kevinohio
By middlebrookgt
By Rick Shropshire
I recently picked up a 2000 warrior 350 and it doesn’t have the air filter box so I was thinking about using a clamp on filter directly on the carb. Anyone know what I need to get or where I can find it? The one I ordered goes in the box and won’t fit directly on the carb.
By Need-help-with-quads
By Gwbarm
