By cruteg8
I was thinking about trying to repair some cracks in the plastics of a Lakota Sport i just purchased has anyone ever tried (U.S. Chemical & Plastics USC GarageTM Flexible Glaze USC-77704 it) https://www.ebay.com/itm/364866165725. i was thinking jb weld for plastic then using this as a bondo that can be sanded smooth
By jeffinotown
By sunn
Temp was mid 70's, with ATV not run for maybe a month but on battery maintainer with full bat charge noted. The atv started, but then died a couple times after repeated attempts. But when run awhile everything was ok. Although when starting now I do hear the fuel pump humming but seems to take a few ,"long" seconds before full prime pressure.
I've priced a replacement fuel pump on eBay for less than $40 so am tempted to simply replace it for good PM. Just had all covers off so looks really easy to replace.
Any ideas?
By Olchap
Hi, I am new to this forum and I am happy to be here. I purchased a Yamaha 350 Big Bear without a title and I cannot find a Vin number to find out what year it is. I am hoping someone here can help me identify this atv. I checked on the main frame near the front A-arm left side found nothing. I checked up near the radiator and found nothing. Where else should I look? See image below.
By exalrod
Hello All !
Could anyone help with this?
