Have a 96 warrior that cuts out when I hit about 3/4 throttle ha e rebuilt the carb multiple time have tried a 140, 145, and a 147.5 and it still has not changed tried 2 different carbs with still results I have bypassed the Neutral switch and the reverse for the rev Limiter usually can work these problems out..any one have any ideas or could no what it is maybe a relay...i even checked my woodruff key to make sure that didn't break it's good
Well I got it figured out it was the accelerator pump the rod on it got a little bent Causing it not to go up and down straightened it out it it works flawless now..thanks for the input tho
    • By Elk
      2002 Polaris Magnum 325
    • By OldATVowner
    • By DexKing
      Good day everyone!
      I am pretty new to ATV/UTV/Small engine repairs and would like input on your absolute must-have specialty tools for maintenance and repairs. Aside from the obvious wrenches and sockets, what are some more specialty type tools you use for troubleshooting? I don't plan to open a repair shop or anything, I just do this as a hobby. Looking forward to your responses!
