Similar Tagged Content
By Wali
I was riding my 400ex one day and when i shut it off to put it in the garage i tried to start it put again to drive it into the garge and it wouldnt start.I put a compression tester on it and its like 30 psi with out throttle and 0 psi WITH THROTTLE.
when i put my finger over the hole it fell likes its pulling my finger in more then its pushing it out
Has good spark.When i took it into the shop the said it had 1oz of oil in it and a tiny pit of metal shaving(TINY BIT LIKE 30 flakes)
When i try to pull start (push start/roll start) it made a not normal sound and wouldnt stay running.
If my bottom end is blow why would it still turn over fine,
Are my valves siezed or not working properly
or is my timing off causeing valves to not open in correct order with fire
PLEASE HELP all help is appreciated
By Hunter Aldridge
Some times I get spark some times not can ride then it just dies and wont get spark it has new cdi box and stator but I don't know if it has the pickup coil I'm at a loss
By William Sims
I have a 400 4by4 ,2005 green model,
wounding how many different CDI boxes will work on it
By jerry houston
Eiger 400 Suzuki runs fine Cook-Out joke face off the handlebars put it back on and will not start now will crank no no spark
By colin james
View File 2012-2014 Polaris Sportsman 400 HD Service Manual
This the factory service manual for the 2012- 2014 sportsman 400 hd service manual
Submitter colin james Submitted 02/08/2019 Category Polaris ATV
Similar Topics
By Brennon Heflin
So I bought a 2000 quad runner 250. I'm having some issues an wondering what it could be I replaced the pet cock valve an the fuel filter an pump inside tank I also put a voltage regulator on it. The problem I'm having is that when u give it half or more throttle it bogs down an loses power what could it be the bike is almost like new an cant figure it out any help would be great
By Susan Makowski-DeGraw
My quad runs, it starts up runs for about 10 minutes and then it dies if you let it sit for 10 minutes it’ll start back up ride for another 10 minutes and then die again, trying to figure out why it keeps stalling
By smitht18
Looking for the rectifier. Most bikes have near magneto. It appears the KQ has it in front.
Can someone tell me exactly where it is?
Bike not charging and magneto checks out ok
By Hunter19
How are you doing guys I just joined I have a 1998 Suzuki King quad I’m having problems with high RPMs the ATV idols perfectly but soon as a throttle up it doesn’t stall but it just bogs down it has no power any suggestions thanks
By abi
Hello ladies and gents. Just picked this guy up in October and getting around to doing the required maintenance to make sure everything is right before any long rides or work is done.
Some background: I am I believe the 4th owner, (however the 3rd didn't actually ride it). It has unknown hours or odometer due to what appears to be a common issue.
I have noticed the fuel gauge doesn't work (just keeps flashing empty),
I did come across a google search that mentioned these were a common problem but was fixed by replacing the dash (seems like overkill) and another post mentioning someone attempting a fix.
Any particular issues on these quads to pay attention to beyond the dash ?
Going to be replacing the rear tires, oil change, filters and plug. Anything else I should do with an unknown history such as diff flush/change ?
I believe there is a service manual here but I need a few more posts. Hopefully this post will drive some answers and more questions I might have. Thanks!
