2018 Honda Fourtrax Foreman Rubicon 4x4 Review
    • By bco20
      does anyone have an owners manual or repair manual i could download ?i got a 2018 king quad 5oo eps special edition can not find either anywhere thanks
    • By GrizzlyRider
      The 2024 ATVs are out and I was just looking at the websites for Yamaha and Suzuki. The Grizzly and King Quad have come a long way, probably two of my favorite quads over the years. Both of these come with power steering but I almost like the King Quad styling a little more. The plastics haven't changed much over the years either, mayeb a little more rugged. The King Quad racks are more like the Polaris plastic racks (I think they were the first to introduce these) but on a closer look, I think its just plastic covers over the traditional metal racks. The Grizzly still keeps the old style metal racks. I like the display/instrument panel on the Grizzly more.
      2024 Suzuki King Quad
      2024 Yamaha Grizzly
      Thoughts on these two? Here's a pretty good comparison of both 2023 models. I didn't know some of these things like no seat latch on the Grizzly and hydraulic rear brake vs cable. Good video to watch if you are consideting these:
      Grizzly 700 vs KingQuad 750! 2023 Full Shootout!" width="200">
    • By huntindog
      TIA
    • By 2wdrancher
      Hello everyone I have done a ton of research on doing this conversion because I hate getting stuck in the stupidest places and not being able to back out. I will be documenting my conversion here and on a couple other forums and probably post a couple videos on YouTube. So what I’ve come up with is all you need is a front axles, front propeller shaft, the final shaft inside the engine and the 4x4 front engine cover . I will list all the part numbers for everything that you need and prices from about six months ago (sorry) , you DONT need to switch out hubs, knuckles, or anything like that, and if you want differential lock lock like the foreman and Rubicon you can get a foreman Rubicon front differential and propeller shaft with the diff-lock and get a knight sure four manual actuator for it and voilà you have four-wheel-drive rancher. Input from you guys is greatly appreciated thank you for your time!
      Note: I would definitely get the aftermarket HD axles because they are definitely stronger and are around the same price as oem
      FINAL SHAFT
      23611-HR3-A40  =$80.48
      BEARING
      91006-HP5-601   =$11.11
      OIL SEAL
      91202-HR0-F01   =$ 7.94
      COVER ASSY., FR. CRANKCASE
      11300-HR3-WB0   =$206.99
      PROPELLER SH AFT
      40400-HR3-A20   =$91.50
      FINAL GEAR
      41400-HR3-W50   =$714.88
      FINAL CASE BRA CKET
      50350-HR3-A20  =$7.40
      FLANGE BOLT
      95701-08016-08  =$1.49
      R. SHAFT SET
      44250-HR3-WB1  =$240.64
      L. DRIVESHAFT
      44350-HR3-WB1  =$240.64
      This is all for the 2x4 - 4x4  lever that comes in stock on the ranchers. I would definitely recommend looking for parts for wheelers on marketplace,  or craigslist
      001
      NUT, ADJUSTING
      41560-HP5-600
      $6.51
      002
      CABLE, FR. FINAL CLUTCH
      41570-HR3-A21
      $6.56
      003
      SPRING, CLUTCH CABLE
      41571-HP5-600
      $1.95
      004
      CLIP, CLUTCH CABLE
      41573-HP5-600
      $3.23
      005
      GROMMET, CLUTCH CABLE
      41716-HP5-600
      $3.12
      006
      LEVER, FR. FINAL CLUTCH
      54030-HP5-600
      $8.91
      007
      PILLOW BALL, FR. FINAL CLUTCH
      54031-HP5-601
      $10.87
      008
      BRACKET, FR. FINAL CLUTCH
      54040-HP5-601
      $11.19
      009
      SPRING, FR. FINAL CLUTCH
      54041-HP5-600
      $1.86
      010
      GATE, FR. FINAL CLUTCH
      54050-HR3-A20
      $4.55
      011
      GRIP, FR. FINAL CLUTCH
      54321-HP5-600
      $8.95
      X2 012
      BOLT, FLANGE (6MM)
      90111-162-000
      $2.54
      013
      NUT, SELF-LOCK (6MM)
      90343-ZE6-000
      $1.70
      014
      JOINT B, BRAKE ARM
      95015-32001
      $0.82
      X3 015
      BOLT, FLANGE (6X12)
      95701-06012-00
      $1.34
      Or Forman 520 w diff lock
      FINAL GEAR
      41400-HR4-A21  =$732.49
      PROPELLER SHAFT
      40400-HR4-A20  = $92.54
      And you definitely need the sure four locker for this
