    • By canamKID
      20260711_150338.mp4
      Best ATV for Older Riders
      Polaris Sportsman 570 EPS
      Best Reliable ATV for Seniors
      Honda FourTrax Rancher EPS
      Best Features
      Best Premium Comfort ATV
      Can-Am Outlander MAX
      Standout Comfort Features
      Best ATV for Easy Handling
      Suzuki KingQuad 500AXi
      Why Older Riders Like It
      Yamaha Grizzly 700 EPS
      Best Features
      Arctic Cat Alterra 600 TRV
      Key Advantages
      Electric Power Steering (EPS)
      Automatic Transmission
      Lower Seat Height
      Two-Up Models
      Hand Warmers and Heated Grips
      Adjustable Suspension
      Buying Too Much Power
      Ignoring EPS
      Choosing Aggressive Tires
      For most mature riders:
      Final Thoughts
    • By Coyote251
      Interesting Jumper Pack. No battery to die and works well. It is basically a string of capacitors that takes the minimun voltage that is in your battery , even though its not enough to start the machine, it is enough to fill the capacitors and boost the battery for starting. The only problem is if the battery is completely dead wont do any good, but you can charge it in 2 minutes with your car battery. Interesting idea if the capacitors hold up, time will tell.
    • By Coyote251
      service manual - 2016 Can-Am Outlander L-Series
