2011 ranger 800xp. New fuel pump/plugs and wires.  Idles fine falls flat on its face when accelerating. Acts like you shut the key off and turned back on fast.  Any input would be great
  • Ajmboy changed the title to junk ranger - 2011 Polaris Ranger 800xp Acceleration Issue
Hi @austinC I moved your topic to the Polaris UTV forum and added the full UTV info and issue, so hopefully you get some help with this.
So just so I understand, it starts fine and idle, but when you give it gas it bogs down? If so, sounds like a fuel starvation issue.
    • By flyinbrian365
      What's Covered:
    • By 97kingquad
    • By Werewolf
      Airbox is getting oil in it from crankcase vent, the engine has 2 cups of oil when I drain it. I drained it out put it back in the reservoir, prime it start it up after a few minutes it starts spitting oil out?
    • By ath1981
      Got a 2011 425 EFI. It eat 2 belts, so I replaced the drive clutch assy, rollers, spacer and movable face. Put on a new belt and after 30 min of riding, it eat another belt. any clue what can be causing this?
    • By Matdum
      Is it common to replace them ? I think one of mine doesnt mist well and cause too much fuel goes to exhaust. Motor is full rebuilt and stink , like combustion isnt going very well
      anyone?
