Any idea what would cause the cotter pin to break and the nut to back off?  The loose hub is wollored out so its trash and the axle splines show a little wear.   I'm going to replace the hub and I'm curious how much play is acceptable before I need to replace the axle?
  • Ajmboy changed the title to 2013 Honda Rancher 420 loose hub
It is a hand-me-down from my father in law.  He bought it new and uses it on his farm.  I thought it was strange too since both back tires are new and it should have been noticed when they were changed.  When I took the wheel off the hub nut was loose and the cotter pin was in three pieces laying in the wheel dust cap.  There was some rust on the axle splines so it was loose for a while.  To be safe I replaced the hub and it was still a bit looser than it should be so I have an axle on order.
Sounds like we're alike. I can't stand things not being right on any of my stuff either. Hope it works out for you. Unfortunately many dealerships have a shortage of qualified people. Changing tires is considered simple so it probably got done by the least skilled guy there.
Sent from my moto g(6) using Tapatalk
    • By tds7
    • By middlebrookgt
    • By Olchap
      Hi, I am new to  this forum and I am happy to be here.  I purchased a Yamaha 350 Big Bear without a title and I cannot find a Vin number to find out what year it is.  I am hoping someone here can help me identify this atv. I checked on the main frame near the front A-arm left side found nothing.  I checked up near the radiator and found nothing.  Where else should I look?  See image below.
    • By Ironworker709
      I have Grizzly 700 that has been pretty much totaled out in a bad accident, but it will still run and drive good...
      Will this engine swap into any of the Yamaha UTV's like thr rhino and Viking 700's?
      Was just going to sell it as is for a engine for someone who needs one pretty cheap..but been thinking about getting a UTV for the family and maybe find one with a blown engine cheap and swap it out
      I already an excellent shape 2001 Big Bear 400 4x4 for us..but kinda been looking for a good used UTV for us and the grandkids on our property to play with
      Not sure of the year..i can't remember what year it was when i picked it up for a buddy a few years ago..he went to jail after he totaled this thing and told me to pick up a few things at his house he was renting and just keep them for myself since he owed me a bunch of money before the landlord sent them to the dump...
      The first picture is when i went and picked it up for him..second is how it is now..frame is all twisted up and plastics are fubarred..going to sell the rims and tires.they stick out way too wide on my Big Bear
