I replaced the one way starter clutch on the 03 400ex I just picked up and got it running.  I took it around the house and then brought it into the garage went back about 10 minutes later and started it and it idled for about 3 minutes and made a clunk and shut off.  Now its doing the same thing as before the one way clutch was replaced.  What would have made it do that?  Also i dont know what all has been done to the motor.  I was told it was bored and piston shaved.  I do nopw it sounds like the valves need adjusting.  Any ideas on why the one way clutch would brake like that?
I think the  sprag ( one way clutch)  is being blamed for another problem.  I can't tell what  is  making it stall  after  idling  for a few minutes, but I very  much doubt it is the sprag..  It is more  likely a fuel  problem . Is it running rich with a  lot of  carbon  black  building up  on the  spark plug?
It made a clunk and stopped.  Now the atarter just spins and the mottor doesnt kick over like it did when the one way was bad.  I think the one way broke again.
    • By HoldenBoy
    • By crankin
    • By quadnut20
    • By sunn
      The clutch engagement on my 2021 cforce 400s was approx 2700 RPM, very abrupt/not smooth.   I obtained a "kit" from RNG consisting of a blue painted spring (spring force unknown) with 12 gram weights, as measured on my postal scale.  Installation was easy; 18 mm and 30 mm (not 32 mm as seen on other writings) impact sockets for clutch housing removal.  The resultant clutch engagement was still up to approx 2500 and very abupt/not smooth.
      The RNG spring was slightly longer than the stock spring, but felt slightly easier at initial downward force but had more resistance than stock as I continued to push down.  RNG would not tell me what the spring force was.
      I am really struggling to get any answers on the best combination of spring / weights to achieve a smooth engagement of maybe 1800 RPM.  Note; idle RPM is approx. 1600.
      I have searched all the forums and cannot find good information, and RNG appears to be not willing to share information.  What gives here?  Anyone with experience to share?
    • By Asand211
