1996 Polaris sportsman
By OldATVowner
By Mikey509
By LMI
By hengstserepair
Nuetral: Runs as expected
Lorne
By sandman001
This 2006 ArticCat dvx400 didn't have a reverse cable. I got one and am wondering how it routes? If someone has a dvx400, could post a pic of there reverse cable routing, it would be greatly appreciated. Thanks
