1998 Suzuki King Quad 280 Checking fluids
By
Mustangiiman01, in Suzuki ATV Forum
Similar Tagged Content
By Abbeypalm
While cruising, my 2011 750 king quad suddenly shut down. As it happened, red lights on the display flashed. Any ideas? My head lights suddenly stopped working about a week ago, if that helps. I have no power at all. Thanks
By smitht18
Looking for the rectifier. Most bikes have near magneto. It appears the KQ has it in front.
Can someone tell me exactly where it is?
Bike not charging and magneto checks out ok
By Hunter19
How are you doing guys I just joined I have a 1998 Suzuki King quad I’m having problems with high RPMs the ATV idols perfectly but soon as a throttle up it doesn’t stall but it just bogs down it has no power any suggestions thanks
By Clint Osborne
2010 Suzuki king quad 750 axi 4x4 light stays on and 4x4 not working any suggestions thanks
By hornythrony
Hey I have a 07 king 700 there's lots of times that the quad will stall when the fan turns on also have to bump motor 2 or 3 times before starting to start it (makes fuel pump go on 2/3 times) anyone having or had this issue?
Similar Topics
By Abbeypalm
By Sha35297
Customer brought in this bike for no response when put in gear. After getting into the transmission I found the main shaft for the clutch had been stripped where the gears mesh up and also the shaft for the gears had been broken in half. I replaced all broken parts and reassembled the transmission. Now it makes a knocking noise in low gear and in reverse. When in neutral it tries to roll reverse while making the same knocking noise. I’ve disassembled and reassembled it several times with the same result. Any ideas??
By Brennon Heflin
So I bought a 2000 quad runner 250. I'm having some issues an wondering what it could be I replaced the pet cock valve an the fuel filter an pump inside tank I also put a voltage regulator on it. The problem I'm having is that when u give it half or more throttle it bogs down an loses power what could it be the bike is almost like new an cant figure it out any help would be great
By DrtyGrlKristin
By smitht18
