Sputtering and backfire on a 03 Kawasaki 360 Prairie
By ButchM
By dkgg5755
By BruinBeater
Hey all, BruinBeater here. Just joined up from the Pittsburgh, PA area.
I'm the unofficial mechanic of the extended family. In the past month or so I've replaced a transmission in a Chevy Silverado, rust repair on a Chevy Malibu, electrical repair on a Subaru Crosstrek, overheating issue solved on a Can Am Commander, and right now I have a pair of Grizzly and a Bruin 350 in the garage. Both have a no start condition and have been sitting for 2+ years.
By HighPlainsIT
My son's trying to get a 2003 Prairie 360 running. Over a year ago, he'd rebuilt the carburetor using a SHINDY 03-112 rebuild kit from JT Cycle & ATV, and it was working fine; however, when it wouldn't run recently, he took the carb apart and the jet needle was rusted in place. He cleaned that up as good as possible and replaced the jet needle with the old one that wasn't rusty. Now, he can only get it to start about 1 out of 5 tries, and when it does start, it won't run unless the choke's on. The spark plug's good and is sparking. It has compression. Any ideas on what he should try next or look into?
By davefrombc
It would be helpful at times to have a button where we could cont the Admin. to make some changes to our posts.
