It will not turn over with starter and will not fire while pulling pull start.
The only thing that Ive tested that didnt test correct is the kill switch I read on another forum to test black and Black/white wire for continuity when in off position I did and it shows continuity like it should. Then when you slide it to run it should be open and show no continuity which mine still shows it while in the run position. So I unplugged the CDI just for sakes of doing it and the kill switch then tests correct. So where should I test next without unplugging CDI?
This is how all this started..
Was riding late one evening when my headlight bulbs blew and busted bulbs didn’t blow fuse. Few days later it just cuts off like turning the switch off look and it blew ignition fuse tried another and blew it. So come to find out fried CDI replace it with a cheap one off amazon that you can no longer find so I wonder if it’s really any good.... and rec/reg and new battery no more fuse blowing but won’t turn over with starter. Jump solenoid and it turns over but no spark at all.
It acts just like a safety switch. When I test my kill switch it says with switch in off position it should show continuity on black and black/white wire it does then says to slide it to run position and it should be open no continuity but it still reads continuity.
Multiple problems,no spark,no crank.A blown fuse is rare.A vibration damaged fuse is common.Busted bulbs?as in the glass broke?Anyway,we need more information.Does sound like you have a wiring harness rubbed through,and have a short.Also,checking the kill switch,it has to be unplugged from the harness.Also,rarely,the back of the ignition switch comes loose,and turns,can cause strange problems.
Fuses are all good have checked them all with test light. Replaced rectifier/regulator and CDI with cheap one it stopped blowing ignition fuse but still not turning over woth start button or firing. I just wonder if CDI is proble since black/white wire runs into it? So how do I need to check kill switch?
At the starting circuit cut off relay there is 2 red/white words that go in a slot together and 1 red/white wore in a slot a blue/white wire in a slot and a yellow/black wire in a slot all of these are hot until you press start button except blue/white it’s the only one that loses power.
  • 9 months later...
    • By realpilot
    • By logray
    • By OldATVowner
