2000 Yamaha big bear 400 2x4
AFricks88
It will not turn over with starter and will not fire while pulling pull start.
The only thing that Ive tested that didnt test correct is the kill switch I read on another forum to test black and Black/white wire for continuity when in off position I did and it shows continuity like it should. Then when you slide it to run it should be open and show no continuity which mine still shows it while in the run position. So I unplugged the CDI just for sakes of doing it and the kill switch then tests correct. So where should I test next without unplugging CDI?
This is how all this started..
Was riding late one evening when my headlight bulbs blew and busted bulbs didn’t blow fuse. Few days later it just cuts off like turning the switch off look and it blew ignition fuse tried another and blew it. So come to find out fried CDI replace it with a cheap one off amazon that you can no longer find so I wonder if it’s really any good.... and rec/reg and new battery no more fuse blowing but won’t turn over with starter. Jump solenoid and it turns over but no spark at all.
Multiple problems,no spark,no crank.A blown fuse is rare.A vibration damaged fuse is common.Busted bulbs?as in the glass broke?Anyway,we need more information.Does sound like you have a wiring harness rubbed through,and have a short.Also,checking the kill switch,it has to be unplugged from the harness.Also,rarely,the back of the ignition switch comes loose,and turns,can cause strange problems.
Fuses are all good have checked them all with test light. Replaced rectifier/regulator and CDI with cheap one it stopped blowing ignition fuse but still not turning over woth start button or firing. I just wonder if CDI is proble since black/white wire runs into it? So how do I need to check kill switch?
  • 9 months later...
    • By Tuzz
    • By p5200
    • By Uglyside38
      Has anyone had any luck converting an older quad from a 7 wire CDI to the newer (and cheaper) 5 wire CDI?
      I have a 1988 Suzuki Quadrunner and I believe the CDI is on it's way out...🤦🏼‍♂️ A used CDI from 1988 goes for $250-$300 on the bay...and that's when you find them. The Chinese CDIs for the 1990 and up quadrunner are only about $40. I have read a blog from a guy who says it's possible and that 2 of the wires can be omitted if the rectifier is a newer one also. Any experience with this would be greatly appreciated!!!🤙
    • By Werewolf
    • By cosmacart
      Hi all, iam from ohio and i have a 2013 yamaha rhino SE black . I might sell it but i dont know what its worth. So can anyone give me an idea what to ask for it?? This is not a scam,,its only a question thanks in advance!!
