You have replaced the major components, two other things come to mind as to what is causing this, maybe a bad ground or pickup coil in the stator assembly. You could try unplugging the wiring from the pickup coil. and check for corrosion clean them up good and see if that helps.
  • 4 months later...
Back to the wheeler,bought a service manual. Should have done that long ago. Reading in there on that machine there is a switch in the throttle thumb box if the throttle cable has any slack in it the switch will make and no spark. Another thing I found interesting on this, there are no fuses. Thanks
Ok. And so was it the throttle safety switch causing the one spark ?
We quite often see a one spark problem in here, on all sorts of makes, most of which don't have the throttle safety switch.
Have you tried unplugging the black wire from the kill switch? If the kill switch is bad that will allow it to start. I'm assuming it might be similar to my 500 Scrambler. Might be worth checking. My kill switch was corroded  after cleaning its been working fine. But unplugging black wire should let it have spark if similar to mine good luck!🙂
    • By jimbo69
      my outlander 800 sometmes starts and does good ouker times starts but will not idle .any one else have same problem?
    • By realpilot
    • By 88bigbear
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
