By Jacksonbell
I just went out to start my 2004 polaris sportsman 600 and nothing happened. It didnt have power to the dash and wouldn't turn over. I have no idea why, but it's not the battery because the winch still works. Can anyone help?
By PolarisRich
I've never done this before but after reading a few thread I decided to check my valves for the first time and to my surprise it was much easier than I thought.
My bike is a 2005 Sp 500 HO.
I first pulled the seat and the right side panel off, and that's it! It wasn't too bad to get at.
Next I pulled the spark plug out and removed both the head cover ( 8-8mm bolts)
[ATTACH]1021[/ATTACH]
then the side cam cover (5-8mm bolts).
[ATTACH]1023[/ATTACH]
Also remove the plug in the recoil cover (14mm bolt) to see the timming marks.
[ATTACH]1022[/ATTACH]
Next I turned the engine over with the pull cord untill it was at TDC of the compression stroke.
The best was to tell that your at TDC of the compression stroke is to rotate the engine until the
timing marks are parallel to rocker cover gasket surface.
The cam sprocket locating pin will be facing upward directly in line with the crankshaft to camshaft center line.
Now fine adjust by looking into the timing hole in the recoil cover and line up the upside down "T" on
the flywheel into the center of the hole.
Now using a feeler gauge, slide the .006" (.15mm)blade between the top of the valve and the bottom of the adjuster and adjust accordingly
[ATTACH]1024[/ATTACH]
[ATTACH]1025[/ATTACH]
To adjust, Loosen the locknut (10mm) and check clearance with a feeler guage. Clearance should be .006" (.15mm) for both, intake and exhaust valves. Turn the adjuster with a stubby flat blade screwdriver untill the proper clearance is achieved then tighten the locknut (5.8-7.2 ft. lbs) while holding the adjuster in place with the screwdriver. Re-check the clearance with the feeler guage one last time and re-assemble the covers (72 in.lbs) and plugs.
The only thing that i noticed was that I had to clean and silicone the side cam cover other than that I found the whole process rather simple.
I'd give it a 4 out of 10 on the skill level scale.
I hope this helps!
Thanks Rich
By Sportsman500guy
By quadcrazy
Covers the following models:
1985 Scrambler Trail Boss
1986 Scrambler
1986 Trail Boss
1986 Scrambler
1986 Trail Boss
1987 Trail Boss
1987 Cyclone
1987 Trail Boss 4x4
1987 Trail Boss 4x4
1987 Trail Boss 4x4
1988 Trail Boss 2x4
1988 Trail Boss 4x4
1988 Trail Boss 250 RIES
1989 Trail Boss
1989 Trail Boss 2x4
1989 Trail Boss 4x4
1989 Big Boss 4x6
1989 Big Boss 4x6
1990 Trail Blazer
1990 Trail Boss 250
1990 Trail Boss 2x4
1990 Trail Boss 2x4 350L
1990 Trail Boss 4x4
1990 Trail Boss 4x4 350L
1990 Big Boss 4x6
1991 Trail Blazer
1991 Trail Boss 250
1991 Trail Boss 2x4
1991 Trail Boss 2x4 350L
1991 Trail Boss 4x4
1991 Trail Boss 4x4 350L
1991 Big Boss 4x6
1991 Big Boss 6x6
1992 Trail Blazer
1992 Trail Boss 250
1992 Trail Boss 2x4
1992 Trail Boss 2x4 350L
1992 Trail Boss 4x4
1992 Trail Boss 4x4 350L
1992 Big Boss 4x6
1992 Big Boss 6x6
1993 2502x4
1993 3502x4
1993 2504x4
1993 3504x4
1993 Sportsman
1993 2506x6
1993 3506x6
1993 Trail Boss
1993 Trail Blazer
1994 3002x4
1994 4002x4
1994 3004x4
1994 4004x4
1994 3006x6
1994 4006x6
1994 Trail Boss 2W
1994 Trail Blazer 2W
1994 Sportsman 4x4
1994 Sport
1995 3002x4
1995 4002x4
1995 3004x4
1995 Xplorer4x4
1995 4006x6
1995 Trail Boss
1995 Trail Blazer
1995 Sportsman 4x4
1995 Scrambler
1995 Magnum 2x4
1995 Magnum 4x4
1995 Sport
By Ajmboy
I went to NYC over the weekend to see the tree at Rockefeller with tha family, and on the way down from about 50 miles north could not help but keep looking in the sky while driving at diffent lights. Planes, small planes, choppers? Some of them looked like slow moving drones but not really sure. If you are in the tri-state area, you can't help but wonder what's going on... thoughts?
Create an account
Register a new accountSign in
Sign In Now
