Hi everyone. I need some help please. My quad ( shineray 250 2007 model) idles great and reves up but when i put in in gear it dies. I checked on youtube and they said it might be sticky clutch so i took it out and cleaned and put it back together but it still does the same. Could it be my air/fuel ratio?? Please help
Hi
I had an Eton 150 - CVT drive. The variator weights let the clutch engage too quickly, before the engine could develop power. By changing the weights the clutch engages later and - no stall.  I can't give credit to the source of the information that I found 'case I didn't save it.
First things first.doc
Thanx guys. Im busy with the air screw and its driving finally. But now theres another problem, when im driving in 1st and give it throttle it loses revs and want to die, but when i pull clutch it idles again???? What could be wrong??? I did clean the carb just now
Edited by Francois9314
Forgot something
@bdaigleyamaha open your clutch cover on the right hand side and take out the clutch and just wipe it off, when you put them back in dont mix them up. Put them back in the same order as the way you took it out. Then adjust your air screw on the bottom of your carb. I got my bike atleast to drive today but still not 100% when i want to give it gas so that i can go to 2nd gear it loses revs and want to die
    • By tflack500tbx
      Background,
      Any Ideas?
    • By crankin
    • By quadnut20
      Just picked up a 2025 Yamaha Kodiak 700 fixing to do a EPI Clutch mod to it since I dropped bigger tires on it !! Air box , exhaust , and programmer next !
    • By harryjr
      hello everybody my name is Harry jr and i recently picked up a 90's Yamaha moto4 225 i beleive and neede a starter was all he said ( i know right ) thats what they all say
      anyway i picked up a starter and installed it and when it is crankling it sounds as if it is not turning over freely as i9f there was a one way bearing not worrking correctly so pulled with recoil and it pulled back so hard i ripped out of my hand so hard it actually hurt now i have pulled and kicked a lot of bikes and such but never felt anything quite like this you can hear it try and fire and kick back but still acts as though somthing holding it back does that make any sense to anybody is it flywheel key , or valves wauyout any help would be great i picked tow of these up for $100 and tring to fix so we can ride as a family thank you in advance.
    • By HHurks
      Hi to all
      Newbie here. Not new to ATVs. Look forward to learning a few new things and hope to maybe help some too.
