7 Mild To Wild Mud Tires
By qcm413
Hi,
thank in advance
By p5200
By alexwv1863
I believe the Kawasaki is either an '03 or '04. Green automatic with shifter on the right side. Rear differential was bad, so I replaced it with another. The 4 wheeler rolled in neutral when I parked it in the shop to work on. Took old diff off and replaced it with another one. The diff I put on, turned before I put it on the bike. Once I put it on the bike, the rear end wouldn't move at all. It's like it's stuck in gear. Bike is still in neutral. I've tried rocking the bike while trying to put it in high, won't budge. Can anyone tell me of something to check or try? I haven't opened up the transmission case yet to see what's going on. What should I be looking for?
By mga
My 2000 big bear 400 4x4 has 26x10x12 tires in front and 26x12x12 in the rears. Trying to find replacement tires those sizes are hard to find, or, when i do, they cost a lot more than i want to spend.
But, there's a lot of 25" tires out there the same size, just 25" and not 26". If i got the 25" it should not make a difference....right?
By Gordo7799
I am looking to replace the Maxxis AT 25x8-12 tires on my Yamaha Grizzly 700 and put on snows. Going bigger to 27" and wider to 9" or 10" is probably a good idea, yes????? I've heard that Maxxis Zillas are good.
I just want to use the quad on the trail to get into the lake and then go ice fishing.
Appreciate any and all advice.
Thank you!
Create an account
Register a new accountSign in
Sign In Now
