The atv ran fine but I let it sit for a season with gas in the tank so in the previous carburetor it had trash in the carb. So I cleaned it and popped it back on and it was doing the same thing as it is doing now but worse. So I put a new carb on and cleaned the tank and put fresh gas in it.
On 10/2/2018 at 8:42 PM, rdlsz24 said:
Did it used to run fine? If so, what was done around that time? Fresh gas?
Rob
I see you cleaned the tank did you also clean the gas valve at the bottom of the tank ?
And also make sure the vent at the top of the tank on the gas cap is not blocked. It seems like it’s statving for fuel. What is the air/fuel mixture screw set at ? And has anyone messed around with the main jet needle setting on the carb slide ?
Top of fuel top of fuel tank is clear. Have not cleaned the valve. The screw is set at OEM 2.5 out I’ve played with the main jet setting but it is now back at the middle setting.
Don’t be afraid to try and move the clip in all spots and try to see how it operates.
Also is the float free from any hang ups?
If you are confident that the carb is cleaned, properly reassembled and all good with the fuel delivery then you may have to see if the ignition is breaking down as the engine revs highter.
Is there a rev limiter on that bike ?
  • Ajmboy changed the title to 2003 Yamaha Wolverine 350 bogging
The rev limiter has been disabled
    • By Elk
      2002 Polaris Magnum 325
    • By 88bigbear
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By mehim
