2005 Polaris Sportsman 700 EFI Owners Manual
By cavry
O3 sat a while. Engine is running fine. I got it into neutral, did some general tune-up and cleaning then pulled the shifter pedal up and it locked up and will not release into neutral again. Does anyone have experience with this problem? Thanks for looking and any help.
Cavry
By LashinWheeler
Any help would be great,
Thanks!
By tepin
By flyinbrian365
What's Covered:
By Admin
Topics covered include:
AWD and differential repair
Brake system service
Popular related searches:
Sportsman 570 wiring diagram
