Rancher 420 Rear end rebuild
By Cj Winds
By oztrax
MAX 4 6X6 2008
By 88classic
I have (2) sets of brand new plastics available for Honda Rancher 420 2014-2023. These are genuine genuine OEM Honda plastics. One set is white and the other set is green. The boxes these are in are too big to ship.(Unless you want to pay for it. If so, lookup your own shipping rates from 17325 and box size is 58"x35"x18"). $400
By tcd
Ok recently got a "what i believe" is a 2003 rancher 4x4. I believe it is a 350te. Obviously a project. Wire harness was in bad shape.
Reconnecting wiring harness. Have one harness that does not match...... the end or front side of the harness has this harness. .... appears to be the one that connects to the dash./ LED indicators... The only wires (indicators) that I can find that does not have a match to the main harness connection. These 2 harnesses do not appear to go together . it appear the harness or dash cluster were changed and don't match. Dash/indicator light wire harness was cut off. Attaching pics of both connections. Is there a way to make this work or do I need to buy a new harness or cluster?
By Daniel1971
I have a 2009 Honda rancher that has fuel coming out of the injector but will not crank. I can spray gas in through the breather and it will run a few seconds. Any help appreciated
