My 07 Rancher rear end started roaring on me the other day. I took the inspection plug out this afternoon and to my dismay it was dry full of rusty nasty crap. The pinion was loose and the axle seal was pissing out oil when I tried to top it up. I bought it used and usually check stuff over better but I missed that.  Muuuhhh :( Now I gotta take it apart and fix it. Not gonna be expensive, just time consuming. Hopefully the gears aren't too torn up. I cleaned out the nasty crap with some brake-clean and put in some fresh gear oil. Much quieter now just leaks out all the gear oil cause the seals are shot. I'll fill it up with some lucas and limp it along till I feel like fixing it.
Yeah their not to terribly complicated. Nothin but some nuts bolts and a few cotter keys.  I'm pretty sure the gears are O.K. Just a little corroded. I'll post some pictures when I get it torn apart.
    • By tcd
      Ok recently got a "what i believe" is a 2003 rancher 4x4.   I believe it is a 350te. Obviously a project. Wire harness was in bad shape.
      Reconnecting wiring harness. Have one harness that does not match...... the end or front side of the harness has this harness. .... appears to be the one that connects to the dash./ LED indicators... The only wires (indicators) that I can find that does not have a match to the main harness connection. These 2 harnesses do not appear to go together . it appear the harness or dash cluster were changed and don't match. Dash/indicator light wire harness was cut off. Attaching pics of both connections. Is there a way to make this work or do I need to buy a new harness or cluster?
    • By Daniel1971
      I have a 2009 Honda rancher that has fuel coming out of the injector but will not crank. I can spray gas in through the breather and it will run a few seconds. Any help appreciated
    • By pastorjeep
    • By tds7
      Do any have any experience replacing 2001 Big Bear 400 Front Differential Input Shaft bearing and seal. Getting ready to buy one but the seal and bearing are bad. Any help would be appreciated.
    • By Tim-ANC
      View File 2014 Honda Rancher 420 service manual TRX420
      Honda Rancher 2014 TRX420
      TRX420FA1/FA2 TRX420TM1/TE1/FM1/FM2/FE1
      Submitter Tim-ANC Submitted 06/09/2025 Category Honda ATV
