Hi ; I been having a problem figuring out if theres a special way the transmission gears on my daughters 08 Polaris outlaw 90 {Automatic Trans} I put  it all together and the gears all mesh  correctly it goes into all gears F/N/R but when I try to put the shifter into the  shift gate it will only go into foward and neutral  because the travel is shorter  is a certain way the gears are set ?  I would apprieciate any help you guys can give to me, it rides  perfectly but w/o the shift gate attached im afraid I'll be rebuilding the thans sooner than I think
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
