1991 LT-F4WDX 280CC King Quad Need Right Front Axle
By Shorty51
By hengstserepair
Nuetral: Runs as expected
Lorne
By HHurks
Thank you!
By Ant-Knee
I am trying to rebuild an engine for a '97 Kawasaki Prairie that I recently picked up. There is one head bold that just won't let go. Nothing I do seems to make a difference. I have been putting penetrating lube on it for two days straight and I am afraid it is going to break on me. What is your best advice for getting the sucker out? I have tried a rechargeable impact, a pneumatic impact and penetrating lube.
