My Days Are Numbered ...
Yup, another tracking video ... lachtot.gif ... I know most of you are looking forward to mud, however, I Love Snow. What can I say ...  th_smilienoclue.gif
So, here's a video from a couple weeks ago & I still have two more video's to post since right after that, my season ended ...  th_smilieboohoo.gif
2 hours ago, Asen_77 said:
LOL amazing views :P What is the altitude at this area?
Glad you enjoyed the video Asen_77 ... the altitude in this area is between 8000 & 9500 ft ..... So, when I say I'm gett'in High .... I don't mean with loco weed .......... WOO HOO !!!  :jiggy:
  • Haha 2
    • By jmercer
      Wondering if 1997 klf400b has a decompression, I’m getting 90psi on gauge.
    • By jmeier1981
      Ok guys Ive got a few more for ya.
      TIRES:
      Ive thought about getting new rubber for the wheeler it has some half worn down 25" Kenda executioners on it and Id like to get something that maybe rides a little better and does as good or better in the mud if thats an option. Any tire model suggestions? Also I would like to go to a 27" or mayb e even a 28" are there any disadvantages to doing this would I have to change anything on the wheeler to make up for the larger tires? Ive had a couple people tell me that they would be hard on the clutch.
      WHEELS:
      Ive seen some really nice looking aluminums but not sure they are tough enough to handle trail riding...Are they??? If so what would you reccommend, id like a little off set to give it a slightly wider stance and better stability but a buddy has a set of ITP wheels and the rear is offset a lot compared to the frnt and it looks great but hes constantly getting the back wheels hung up on trails
      SNORKEL:
      I see that the airbox on the brute is where a normal wheelers gas cap would be, so that being said am I good to go with water as long as it doesnt go over that point os is it not sealed up to the box? Also how about the belt and it staying dry, do I need to do anything to ensure that it doesnt get soaked and leave me stranded.
      Oh by the way I love this thing the more I ride it the more Im glad I went with the powerhouse, Ive run with a couple polaris 500s 700s a grizzly 660, and 700 and a couple rincon 680s that were built and they cant touch my stock 750, although she likes her gas thats for sure i got about 50miles and Im needing a refill
    • By Hagbard
      Have a long story that I'll attempt to make brief. I picked up what was advertised as a 1987 LT230E with no cam or valve cover, harness dangling, no plastics, and all kinds of slop in every bushing and bearing, but hey, it was free and I love a challenge. Local guy had a couple 87 230E motors he was selling on craigslist, picked up one of those and a pisspounded DG RCM and header for $100. Went through the harness to start sorting things out and noticed a few key differences, like the stator connectors didn't mate up, one round and one square. Rubbed some of the grime off and found a VIN, Lo and behold - I have a 1990 LT160E, not a 1987 230E... By the grace of who knows what, the 230 just so happened to mount up directly to the 160 frame with no mods. Wasn't until I had broken the seal on starting to chase down the harness leads that I found out.
      As it stood, advertised as a 1987 230E
      After a bit of elbow grease and some eBay raiding.
      Made a new seat cover and found a set of plastics, New carrier bearings, and brakes all around.
      Pulled the steering and front suspension all apart and gave it some love with new bushings and tie rods
      Ordered a small fortune in NOS and China parts from eBay and RockyMountain and after a couple weeks of wrenching and soldering I have a nearly complete wheeler, in pretty decent shape. Cleaned up a Mikuni carb I had laying around and mounted it up with a cone filter and a Lowe's Racing™ intake boot, and fed it some gas, primed the carb and tugged on the started rope a few times, and sure enough it belkched out some soot and fired up, ran for a couple seconds and died. No sputter, just shut off. Checked for fuel startvation, vacuum in the tank, no problems there, plenty of gas in the carb. Suspected clogged air jets, so I pulled it out of the boot and gave it a shot of ether, and it did the same thing, fired up, ran strong for 2-3 seconds and shut off. Then suspected I f*%#ed up the wiring harness somewhere, and re-traced all the leads with my newly colored wiring diagram, thanks to my kiddo's Crayola marker collection, and everything looked good. Started to suspect the CDI, solenoid, or coil might be faulty and was flipping thru the manual when a buddy stopped by with a pair of boat seats for me to reupholster for him.
      He's a little bit of a savant with engines and electronics, and he got curious when I told him my predicament. Three minutes later he said "Hand me a pair of needlenose?" which he used to short the neutral switch to ground, and had me give it another tug. Fired up and ran great, no shutting off, so we deduced that the neutral switch must be at fault and after he left, I pulled it off to troubleshoot, and decided to flick the shifter a couple times with it off to see the little nubbin go around in a cricle. It didn't. I should mention at this point that I had previously changed the oil and while doing so, I took the opportunity to adjust the clutch without consulting the manual because I'm the dumbest guy I know. I did it according to the procedure I had learned for the LT185 I have, and figured the adjuster itself looked the same, they must be the same thing. I loosened the 10mm lock nut, and started turning the adjsuter screw clockwise waiting to encounter resistance, and then back it off 1/8 turn. I was really surprised when it kept turning and turning, but figured it must have been WAY out of adjustment, and went on with business. Figured I might need clutch plates at some point.
      Encountered this problem, and actually read the manual and the procedure is entirely different, and I realized that I had basically "adjusted" it into oblivion. I have since drained the oil and tried to re-adjust it twice, with no luck. Anyone have any idea what I can or should do to correct the issue, or am I missing something else entirely here? (chain is off and sprocket nut is loose, if that makes any difference.) Any insight or advice would be appreciated, thanks.
    • Sell your car with CarBrain
    • By Jim Denton
      These chains look way useful for anyone doing ❄️ snow work.
