hi folks - Today I installed a new starter for my 2001 big bear. 400  The old starter has been dead for several years but I'm just too old now to be yanking that pull cord any more.
Here's my issue:   When I pushed the start button the starter turned over ... and kept going - even after the start button was let go.  After 20 seconds or so the starter finally stopped .  I pushed the start again and the same thing happened ... In fact, it kept trying to start the machine even after I turned off the key!  (for about 10 seconds).  (I also noticed that the positive side of the battery got very hot to the touch.)
Any ideas on what's happening?  thanks
Simple test is as the starter is running/stuck I would unplug the wires going into the starter solenoid and see if the starter stops. It’s the small plug going into the solenoid, If it does stop the starter from spinning  then maybe the starter button itself is getting stuck. If your handy with a tester you can do a continuity test.
    • By Thumpinhard25
    • By Tinkeringreg
