Similar Topics
By mike91
I’m just wondering what year bike i got? it seems the vin has been rubbed off i got it from a auction here in Australia engine starts but seems has a dirty carb wont idle well
and also has a problem I put it in gear and makes a grinding noise but does not move it the neutral light goes out but then when I change gear it grinds more in the higher gears as well I’m guessing the differential is stuffed so wanting to buy new part for it will start the pull down next week
this is the first bike I have worked on used to dealing with cars
By Randel1
I'm having a problem getting a CDI unit that works. The parts list calls for a 4XE-85540-00-00 CDI unit. The one currently on the ATV works but there seems to be a problem with the spark advance curve. It will idle fine an rev. to about 1.5K then starts bogging down sputtering, popping and basically running poorly. If you can get it above 2200 RPM it runs better. I have ordered and returned about 5 replacement modules that will not work at all. The unit currently on the bike has no part numbers or identification other than a Mitisibuchi logo. I am wondering if anyone else has experienced similar problems with replacement CDI's and if so what is the fix? So far I have not found a replacement CDI that will supply an pulse to the Ignition coil.
By Asen_77
Hi All,
My name is Asen and I am from Eastern Europe, Bulgaria. Riding a Yamaha Raptor 700R and this is my first Quad wanted for a vey long time :)
By matw
At a loss...
Runs/starts great when jumped across solenoid. Solenoid has been replaced. Battery has been tested and is good. Doesnt start with start button but starter will engage when machine is running if button is pushed. Machine also is not charging. Regulator has been replaced. Stator has been tested and passes all 3 phases voltage and open to ground all 3 phases. Lights work great with machine running and battery disconnected. Starter solenoid relay has been replaced.
Any help or suggestion much appreciated. I do not have a wiring diagram or manual which i probably should try and get.
By jolio
Just got a '98 Yamaha big bear 4x4 in working condition (so far). Looking forward for some good information on this site about how to keep it alive.
