Hi
What machine would you recommend ? - Really want a solid machine since I am no mechanic but can perform a early service myself.
Just picked up this 2025 Kodiak 700 esp and was wondering if anyone has any suggestion on up grades i should look into ?? I did a EPI clutch upgrade and put bigger tires on it but want to do more !!
