  • Ajmboy changed the title to 1990 suzuki LT-F250 4x4 rear axle
I would think 88-90 or 92 would work. But I would check around online. Look at the parts houses and compare some of the parts diagrams. Are you looking for used that you want to know what range of years would work?
I found a used one but will take 2 weeks to get here. The axles are the same from 88 to 02. left and right are the same and the axles are the same either 2 or 4 wheel drive. Maybe someone else can use this info.
    • By marlon smith
    • By Adamb2025
    • By BillR94
      Thank you for your time
      Bill
    • By JBuckeyeJ
      I got the old thumper going.  My best guess is it sat in a barn for the past 10 years.  Now that I know it runs, it’s time for a valve adjustment and  tracking down a clutch cover.
    • By wjmedic
      right front hub again
